Date/Time: Wed, 25 Nov 2026 23:00:17 +0000
v2878 Duplicated Chart - Save, File >> Save, and File >> Save As do not work
View Count: 535
| [2026-02-08 02:32:53] |
| User719512 - Posts: 548 |
Installed v2878 and noticed Open a chart Duplicate Chart to Another Chartbook >> Create new chartbook >> Yes Close current chart Clicking Save, File >> Save, or File >> Save As do not ask to save the chartbook >> Expected the Save As dialog to show - could swear this used to work this way. File >> Save All or Close Cbook command bar button bring up the "Save any changes made to..." dialog Not a regression from v2877, and I did not install older builds like v2813 to test since I recall that resets the settings that I have in v2813+ for MDI widows/etc. |
| [2026-02-08 05:19:10] |
| Sierra_Chart Engineering - Posts: 25484 |
Clicking Save, File >> Save, or File >> Save As do not ask to save the chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-08 18:46:00] |
So this is probably a really obscure edge case as I first reported above. If following the steps above precisely, the behavior is as reported. IF you interact with the chart, like click on it and make it Active, then the Save operations work as expected. This is definitely not a blocker and has an easy workaround. Guess the question is, for this duplicated chartbook, with just this single chart...should that chart be Selected/Active by default? I am happy with whatever Sierra Engineering decides to do around this...including doing nothing. |
| [2026-02-10 18:42:14] |
We see the problem and we understand why it happens. We will resolve this.
