Date/Time: Wed, 25 Nov 2026 23:00:14 +0000
Need help to capture Low Bid Col & Low Ask Volume
View Count: 427
| [2026-02-07 22:46:17] |
| RK123 - Posts: 11 |
Hello, I'm using Numbers Bars study and need help to capture & compare the following stats - 1) Low Bid Volume and Low Ask Volume - Basically, I want to capture the number of contracts bought & sold at the lowest level of each candle. For eg: in the attached Image, 13 contracts were sold and 2 bought. 2) I also want to capture the delta at each price within each bar. For eg: delta at low of attached candle is -11 and delta at candle's high is 17. 3) I also want to capture what of Imbalance is happening at the lowest and highest point of each candle. For eg: in attached image, that candle has NO imbalance on the highest point but it has seller side imbalance on lowest point. I'm using SC 2789 and if this version doesn't support to capture above data points, please can you suggest if there is another version that supports it |
Private File |
| [2026-02-09 16:16:38] |
To get/check the Volume information at the High and Low of a bar, you can use the "Spreadsheet Formula" study. This study, despite its name, uses the Alert Syntax, and within that is the ability to get volume information at specfiic price levels. Refer to the following: Spreadsheet Formula Study/Chart Alerts And Scanning: Special Functions And refer to the last 3 examples at the following link (#'s 41, 42, 43) for how to specifically use this: Study/Chart Alerts And Scanning: Alert Formula Examples For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
