Date/Time: Wed, 25 Nov 2026 23:00:10 +0000
How to Zero out the DOM?
View Count: 513
[2026-02-07 04:18:43]
User966246 - Posts: 15
How can I reset or zero out the Sold/Bought Contracts columns on the DOM? The only path so far I’ve found is the Volume by Price - Reset Button study, which does reset other studies on the chart when I link it to them. However, none of its settings reset the Sold/Bought columns. Is there a proper way to reset these?
Thank you!
image2026-02-06 23 11 48.jpg / V - Attached On 2026-02-07 04:13:57 UTC - Size: 79.67 KB - 230 views
image2026-02-06 23 14 52.jpg / V - Attached On 2026-02-07 04:15:05 UTC - Size: 125.95 KB - 158 views
[2026-02-09 15:45:37]
What exactly are the columns you are referencing - what are the actual names in "Trade >> Customize Chart/Trade DOM Columns"?
[2026-02-09 18:02:24]
Sierra_Chart Engineering - Posts: 25484
If you right-click on the price scale, there are several clear commands for the market data columns. Although it is not possible to clear the Market Depth quantity columns.
[2026-02-09 23:21:00]
Perfect thank you, Right Click and pressing Clear Recent Bid/Ask Volume does what I was looking for!
