Date/Time: Tue, 24 Nov 2026 18:17:00 +0000
No real time Denali data
View Count: 671
| [2026-02-06 14:40:32] |
| User75568 - Posts: 15 |
I had no problems till yesterday when suddenly the data feed stopped during a trade. Today I do not get any live data and the data connection needs at least 4 trials to connect, but no live data. I send a message log.
| [2026-02-06 14:47:02] |
| User475862 - Posts: 37 |
same problem
| [2026-02-06 15:14:31] |
I reinstalled 2875 from 2877 and get live data now, but do not know if that was the problem. SC tries to connect to futurestrading17.sierracharts.com and fails till it finally finds futurestrading14.sierracharts.com and connects ?
| [2026-02-16 13:10:37] |
Problem with connecting is still persistent, which is not good if you are in a trade and lose connection for whatever reason. 2026-02-16 14:08:15.033 | Software version: 2882 64-bit 2026-02-16 14:08:15.033 | Primary Thread ID: 5144 2026-02-16 14:08:15.033 | Usage end date: 2026-02-26 2026-02-16 14:08:15.033 | Enabled for: Advanced Features 2. 2026-02-16 14:08:15.033 | Enabled for: Sierra Chart Historical Data Service. 2026-02-16 14:08:15.033 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-02-16 14:08:15.033 | Enabled for: Delayed Denali Exchange Data Feed. 2026-02-16 14:08:15.033 | Enabled for exchange2: CME (Trading Account Required) 2026-02-16 14:08:15.033 | Enabled for exchange2: CBOT (Trading Account Required) 2026-02-16 14:08:15.033 | Enabled for exchange2: COMEX (Trading Account Required) 2026-02-16 14:08:15.033 | Enabled for exchange2: NYMEX (Trading Account Required) 2026-02-16 14:08:15.033 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-02-16 14:08:15.033 | Current selected Data/Trading service: Teton CME Routing 2026-02-16 14:08:15.033 | Custom symbol settings values: disabled 2026-02-16 14:08:15.033 | Chart Update Interval: 500 2026-02-16 14:08:15.033 | Intraday Data Storage Time Unit: 0 2026-02-16 14:08:15.033 | Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2026-02-16 14:08:15.033 | 2026-02-16 13:08:15 Local computer time in UTC 2026-02-16 14:08:15.033 | 2026-02-16 14:08:15 Local computer time in SC Time Zone 2026-02-16 14:08:15.033 | Program path: X:\SierraChart\ 2026-02-16 14:08:15.033 | Data Files path: X:\SierraChart\Data\ 2026-02-16 14:08:15.034 | OS Version Number: 10.0 2026-02-16 14:08:15.034 | Locale Setting: C 2026-02-16 14:08:15.034 | Crash reporter started: true 2026-02-16 14:08:15.034 | | Number times message added: 1 2026-02-16 14:08:18.213 | Teton CME Routing | Firm: Dorman/Stage5 2026-02-16 14:08:18.214 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 2026-02-16 14:08:18.216 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-02-16 14:08:18.216 | DTC Client socket (1) | New receive buffer size: 5242880 2026-02-16 14:08:18.216 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-02-16 14:08:39.258 | DTC Client socket (1) | Connect event error. Windows error code 10060: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. 2026-02-16 14:08:39.258 | DTC Client socket (1) | CloseSocket call. 2026-02-16 14:08:39.258 | Teton CME Routing | Failed connections: 1 2026-02-16 14:08:39.258 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-02-16 14:08:39.258 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:08:39.258 | DTC Client socket (1) | Closed. 2026-02-16 14:08:39.275 | DTC Client socket (0) | CloseSocket call. 2026-02-16 14:08:39.275 | Teton CME Routing | Disconnected. 2026-02-16 14:08:39.275 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:08:41.298 | 2026-02-16 14:08:41.303 | Teton CME Routing | Firm: Dorman/Stage5 2026-02-16 14:08:41.303 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 2026-02-16 14:08:41.312 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-02-16 14:08:41.313 | DTC Client socket (1) | New receive buffer size: 5242880 2026-02-16 14:08:41.313 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-02-16 14:09:02.364 | DTC Client socket (1) | Connect event error. Windows error code 10060: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. 2026-02-16 14:09:02.364 | DTC Client socket (1) | CloseSocket call. 2026-02-16 14:09:02.364 | Teton CME Routing | Failed connections: 2 2026-02-16 14:09:02.364 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-02-16 14:09:02.364 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:09:02.364 | DTC Client socket (1) | Closed. 2026-02-16 14:09:02.404 | DTC Client socket (0) | CloseSocket call. 2026-02-16 14:09:02.404 | Teton CME Routing | Disconnected. 2026-02-16 14:09:02.404 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:09:04.420 | 2026-02-16 14:09:04.427 | Teton CME Routing | Firm: Dorman/Stage5 2026-02-16 14:09:04.427 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11093 2026-02-16 14:09:04.429 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-02-16 14:09:04.430 | DTC Client socket (1) | New receive buffer size: 5242880 2026-02-16 14:09:04.430 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-02-16 14:09:04.598 | Teton CME Routing | Network connection to server complete. 2026-02-16 14:09:04.598 | Teton CME Routing | Starting socket receive thread. 2026-02-16 14:09:04.599 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-02-16 14:09:05.134 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-02-16 14:09:05.134 | Teton CME Routing | Sending logon request message. 2026-02-16 14:09:05.323 | Teton CME Routing | Received logon response. 2026-02-16 14:09:05.323 | Teton CME Routing | Server Name: SC DTC Server. 2026-02-16 14:09:05.323 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-02-16 14:09:05.323 | Teton CME Routing | Logon error received from server: Secondary instance is not allowing connections to this server 2026-02-16 14:09:05.323 | Teton CME Routing | Failed connections: 3 2026-02-16 14:09:05.323 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-02-16 14:09:05.323 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:09:05.340 | Teton CME Routing | Waiting for socket receive thread to end 2026-02-16 14:09:05.343 | DTC Client socket (1) | CloseSocket call. 2026-02-16 14:09:05.343 | Teton CME Routing | Disconnected. 2026-02-16 14:09:05.343 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:09:05.344 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-02-16 14:09:05.523 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-02-16 14:09:05.523 | DTC Client socket (1) | Closed. 2026-02-16 14:09:07.338 | 2026-02-16 14:09:07.339 | Teton CME Routing | Firm: Dorman/Stage5 2026-02-16 14:09:07.340 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11092 2026-02-16 14:09:07.343 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-02-16 14:09:07.343 | DTC Client socket (1) | New receive buffer size: 5242880 2026-02-16 14:09:07.343 | DTC Client socket (1) | Connecting to IP: 4.8.170.26. 2026-02-16 14:09:28.394 | DTC Client socket (1) | Connect event error. Windows error code 10060: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat. 2026-02-16 14:09:28.395 | DTC Client socket (1) | CloseSocket call. 2026-02-16 14:09:28.395 | Teton CME Routing | Failed connections: 4 2026-02-16 14:09:28.395 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-02-16 14:09:28.395 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:09:28.395 | DTC Client socket (1) | Closed. 2026-02-16 14:09:28.414 | DTC Client socket (0) | CloseSocket call. 2026-02-16 14:09:28.414 | Teton CME Routing | Disconnected. 2026-02-16 14:09:28.414 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-02-16 14:09:30.436 | 2026-02-16 14:09:30.442 | Teton CME Routing | Firm: Dorman/Stage5 2026-02-16 14:09:30.442 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 2026-02-16 14:09:30.447 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-02-16 14:09:30.448 | DTC Client socket (1) | New receive buffer size: 5242880 2026-02-16 14:09:30.448 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-02-16 14:09:30.637 | Teton CME Routing | Network connection to server complete. 2026-02-16 14:09:30.637 | Teton CME Routing | Starting socket receive thread. 2026-02-16 14:09:30.638 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-02-16 14:09:31.236 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-02-16 14:09:31.236 | Teton CME Routing | Sending logon request message. 2026-02-16 14:09:31.504 | Teton CME Routing | Received logon response. 2026-02-16 14:09:31.504 | Teton CME Routing | Server Name: SC DTC Server. Build=55065. 2026-02-16 14:09:31.504 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-02-16 14:09:31.504 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-02-16 14:09:31.504 | Teton CME Routing | Trading is supported. 2026-02-16 14:09:31.504 | Teton CME Routing | Order cancel and replace is supported. 2026-02-16 14:09:31.504 | Teton CME Routing | OCO Orders supported. 2026-02-16 14:09:31.504 | Teton CME Routing | Bracket Orders supported. 2026-02-16 14:09:31.504 | Teton CME Routing | MarketDepthIsSupported: 1 2026-02-16 14:09:31.504 | Teton CME Routing | Connection to server complete. 2026-02-16 14:09:31.512 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-02-16 14:09:31.512 | Updated verified funded futures trading account ending date to: 2026-03-18 13:09:31 2026-02-16 14:09:31.513 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-02-16 14:09:31.515 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-02-15 23:18:32.127578 2026-02-16 14:09:31.673 | Updated verified funded futures trading account ending date to: 2026-03-18 13:09:31 |
| [2026-02-16 14:48:42] |
Since I am in Europe I have Sierra Chart Server Settings >> General >> Special >> CME Exchange Data Feed Server Address and Port Override: ds14-2.sierracharts.com. It is the same problem in 2875 and 2882. I run SC_ARM64 under Parallels. |
| [2026-02-16 14:53:19] |
| PhiX - Posts: 39 |
I'm receiving current ES data but not market stats data such as TICK and VIX.
| [2026-02-16 14:56:39] |
| John - SC Support - Posts: 48643 |
User75568: You have the following in your log: DTC Client socket (1) | Connect event error. Windows error code 10060: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
So you are having a general connectivity issue. Refer to the following: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-16 15:01:05] |
PhiX: Today is the U.S. Presidents day holiday, so the equity markets are closed, which is why there is no data for those items. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-16 15:07:38] |
Why did it worked without problems till 02-06 and why is it connecting then to futurestrading14.sierracharts.com. after trying all other futuretrading17/16/15 ?
| [2026-02-16 16:38:17] |
We can not say. The error you are getting is a general connectivity issue. You are not able to make a connection for some reason. This is not something on our end, but rather on your connection to our systems. So you need to see what is occurring on your end. We would recommend trying a different ISP, such as connecting to your phone's network to see if it resolves the issue, which will help you determine the problem. why is it connecting then to futurestrading14.sierracharts.com. after trying all other futuretrading17/16/15
When there is an issue connecting to one server, it will try to connect to a different one in the hopes that one of the connections will work. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-16 17:43:49] |
Problem was while trying everything on 02-06, I must have accidentally set: Data/Trade Service Settings >> Main Settings >> Service Settings >> Use Backup Connectivity as Primary to yes
