Date/Time: Fri, 06 Feb 2026 11:17:58 +0000
Position Reconciliation Error: Discrepancy between Sierra Chart and TT
View Count: 11
[2026-02-06 08:08:14]
User368741 - Posts: 91
Hello Support,
I am reporting a position reconciliation issue between Sierra Chart and TT that resulted in an incorrect exit quantity.
Trade Details:
Symbol: KE Wheat
Order Type: Spreadsheet Trading with attached Target and Stop orders.
Initial Position: -6 lots (Short)
Sequence of Events:
Partial Fill: My Target order was partially filled for 2 lots.
Expected Position: My position should have been -4 lots.
The Discrepancy: While the TT platform correctly showed -4 lots, Sierra Chart’s internal position tracking updated to show only -2 lots.
The Error: When my Trailing Stop was triggered, it only squared off 2 lots (matching Sierra's incorrect position) and cancelled the remaining attached orders (which actually had the correct quantity of 4).
Result: I was left with an unintended -2 lot open position because the Trailing Stop triggered based on a false position value in Sierra Chart.
Inquiry: Could you please investigate why there was a failure in position reconciliation from the TT trade server into Sierra Chart following the partial fill? I need to understand why Sierra failed to reflect the true position held at the routing service, leading to an incorrect exit calculation.
