Date/Time: Wed, 25 Nov 2026 23:00:10 +0000
Changing color for the Chart Values for Tools window.
View Count: 511
[2026-02-05 09:54:54]
MissPiggy - Posts: 12
So finally got the thumb out to switch to "dark mode", but I just can't find the color settings for the white background and black text that says "chart values for tools" and "region x" in the attached screenshot.Is it possible?
Also since I'm posting I might as well ask if you are still working on a native client for Linux? Switched around 8 months back and currently running it with bottles/wine under KDE and feels great to finally be rid of windows as main OS but well, still reminded of it daily thanks to so many programs that are windows only.
Thanks in advance.
imageScreenshot_20260205_094953.png / V - Attached On 2026-02-05 09:48:05 UTC - Size: 61.23 KB - 216 views
[2026-02-10 06:46:02]
Sierra_Chart Engineering - Posts: 25484
The header lines in the Chart Values window are simply the Chart Values text and background colors reversed.
[2026-02-10 06:47:27]
Yes, there is general progress towards that objective:
Refer to:
Understanding Sierra Chart Work to Port To Linux and Windows is Doomed
