Date/Time: Wed, 25 Nov 2026 22:50:04 +0000
trade do not fill
View Count: 410
| [2026-02-03 14:21:36] |
| ldepadey - Posts: 73 |
getting a bit fed up with the sierra software these days, paying my monthly bill each month but i cant even get trades to fill, even if i go market they dont fill? can you advise on what this issue is |
| [2026-02-03 15:08:12] |
The Trading Window you have in the image shows that you are trying to enter a Limit order at a price of 0.00. But, you do have order lines that are showing a Sell Limit order at 4934.2 with a Stop at 4949.2. What exactly occurs if you enter a Market order? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-03 15:35:35] |
| Sierra_Chart Engineering - Posts: 25484 |
Refer to: Trade Simulation: How Orders are Filled And the first thing you must do, is remove, the Trade and Current Quote Symbol!: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Do not use that. It is only going to confuse you and is the cause of the problem you are having! Although you should not have any trouble with market orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-03 15:37:37
