Date/Time: Wed, 25 Nov 2026 22:50:05 +0000
Limited CFDs Historical Data (Less than 1 year)
View Count: 480
| [2026-02-03 12:31:37] |
| User980699 - Posts: 4 |
Hi, I am unable to get the historical data for NAS100 and SPX500 before 2025-07-31... For DOW30, I have no problem and can use the Market replay as of 2024-01-01 but with NAS100 and SPX500, when I set 2024-01-01, it load 2025-07-31. I can't believe we have less than 1-year historical data for those popular CFDs... what I am doing wrong? I tried to delete the data and redownload but no result. Thanks! |
| [2026-02-03 13:44:12] |
I found my issue.. I thought chart settings was unique to all my chartbook but it isn't... I had different parameters for DOW30 and NAS100, all good now.
| [2026-02-03 13:50:37] |
Well actually I thought I had solved my problem but when I change the date from 2025-07-31 to 2024-01-01 and click on Apply all, the date revert to 2025-07-31.. strange because my brother just bought Sierra too and he have full historical data...
Attachment Deleted. |
| [2026-02-03 15:21:33] |
Okay so for those reading this post.. I figured the issue.. you have two settings for historical data. You need to ensure to set the same in both place: Global Settings > Data Trade Service Settings > Maximum Historical Intradays Days to Download & Chart > Chart Settings > Load Data Limiting Method: Days to Load Ensure you have both the same otherwise you may face the same issue as me. Working great now :) |
| [2026-02-03 15:21:34] |
| Sierra_Chart Engineering - Posts: 25484 |
Follow through the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
