Date/Time: Wed, 25 Nov 2026 22:50:11 +0000
Accidentally closed my Daily Chart
View Count: 431
| [2026-02-02 21:04:56] |
| Laz1982 - Posts: 1 |
Hi, I`d like to ask your help. I accidentally closed my Daily Chart which up to this point has been working fine. I accidentally closed it and now I can`t find it in my download section nor in the historical data section on the main great console under file dropdown. It`s nowhere to be seen. I`ve made quiet few changes on the chart so I wouldn`t want to download the whole lot again. All of my other charts are working fine though. Can you assist me please? Thank you, |
| [2026-02-02 21:45:36] |
Follow the instructions at the following link if you have not already saved the chartbook: Chartbooks (Workspaces): Restoring Prior State of Chartbook If you have already saved it, then you will need to recover the chartbook from a backup. Sierra Chart automatically backs up the files. Follow the instructions at the following link for how to recover a Sierra Chart backup chartbook: Chartbooks (Workspaces): Accessing a Backup Chartbook File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
