Date/Time: Wed, 25 Nov 2026 22:50:07 +0000
BUG S&P 500
View Count: 344
| [2026-02-02 17:09:15] |
| User220939 - Posts: 65 |
Hi, every day on my daily candle chart, at exactly 6:00 p.m. there is another candle that appears. |
| [2026-02-02 18:32:20] |
What are the following set to: - Chart >> Chart Settings >> Symbol >> Symbol - Chart >> Chart Settings >> Data Limiting >> Chart Data Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-03 06:34:14] |
- Chart >> Chart Settings >> Symbol >> Symbol = ESH6.CME - Chart >> Chart Settings >> Data Limiting >> Chart Data Type = HISTORICAL CHART |
| [2026-02-03 07:55:00] |
| Sierra_Chart Engineering - Posts: 25484 |
You are using Rithmic data, and the only solution we can think of in this case is to set this Chart Setting to No: Chart Settings: Allow Real-Time Updating of Historical Chart (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
