Date/Time: Wed, 25 Nov 2026 22:50:03 +0000
Large Volume Trade Indicator
View Count: 609
| [2026-02-02 15:45:27] |
| more - Posts: 154 |
Hello, in the Large Volume Trade Indicator study, the size of the circles is different between the bid and the ask and this creates confusion. In my opinion there should be no difference between the bid and the ask but only based on the value (the volume number regardless of whether it is bid or ask). This way it would be much easier to observe and more useful. I use the Draw Mode Based on Total Bid Ask Volume Above Threshold - Difference, but the same thing goes for others Draw Modes too. Is it possible to change this thing, which in my opinion is a mistake? Thanks I have attached an image that shows this thing |
| Attachment Deleted. |
| [2026-02-02 18:14:07] |
It is not a mistake, it is just the way it was done. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
