Date/Time: Wed, 25 Nov 2026 22:50:08 +0000
looking for "Percentage of Price" (LTP) for Renko Bar Box Size
View Count: 542
| [2026-02-02 06:50:29] |
| User708340 - Posts: 21 |
Hello, SC support I am looking to replicate a Renko box size assignment method found in tradingview platforms known as "Percentage LTP" (Last Traded Price). In this method, the Renko brick size is dynamically calculated as a percentage of the instrument's current price (e.g., 0.5% of the current price) rather than a fixed tick value. Does Sierra Chart have a native "Percentage of Price" setting within the Renko bar period types? If not, what is the recommended way to achieve this? Can this be done via a Spreadsheet Study to dynamically update the "Bar Size (in ticks)" , or would this require a custom ACSIL tool? Are there any existing studies that can be configured to use price percentage instead of ATR or fixed ticks? Thank you for your help. |
| [2026-02-04 19:16:31] |
| Sierra_Chart Engineering - Posts: 25484 |
This is not something we would add. You will need to create custom chart bars for this: ACSIL Interface - Custom Chart Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
