Date/Time: Wed, 25 Nov 2026 22:50:15 +0000
[Programming Help] - Backadjusted tick data in ACSIL
View Count: 622
| [2026-02-01 17:55:46] |
| Asad1939 - Posts: 21 |
Hi Is ReadIntradayFileRecordForBarIndexAndSubIndex only capable of returning tick data for the active contract? I notice on continuous contract charts it's not returning any data for older contracts. Is there any way to get backadjusted tick data from ACSIL? I couldn't find anything in the docs/forums. If not, is the only alternative to manually read the files and construct the continuous series from scratch in a custom study? Thanks Date Time Of Last Edit: 2026-02-01 17:57:05
| [2026-02-02 23:36:24] |
| Sierra_Chart Engineering - Posts: 25484 |
Yes for sure if the chart is not replaying: Is ReadIntradayFileRecordForBarIndexAndSubIndex only capable of returning tick data for the active contract?
What you want is not supported.Yes or set the chart to 1 Trade Per Bar: If not, is the only alternative to manually read the files and construct the continuous series from scratch in a custom study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-03 01:45:45] |
Thanks for clarifying
