Date/Time: Wed, 25 Nov 2026 22:50:15 +0000
Tool configurations list not showing custom names
View Count: 406
[2026-02-01 17:11:50]
WarEagle - Posts: 80
I updated the software this weekend (2870), and now my custom tool configuration names do not show in the main menu "Tools...Current Tool Config" list. These names are showing as the default "Config 1", "Config 2"...etc. However, the "Configuration..." menu option that I have on my right-click menu shows the correct custom names for each configuration. So I can change a drawing manually one at a time, but if I want to set the tool to a certain default configuration, I have to recall which one matches the default config numbers.
[2026-02-02 23:34:50]
Sierra_Chart Engineering - Posts: 25484
We are checking on this.
[2026-02-03 00:54:01]
This will be resolved in the next release.
