Date/Time: Wed, 25 Nov 2026 22:42:30 +0000
[Programming Help] - DOM from another Chart
View Count: 464
[2026-01-31 00:21:18]
KylieV1618 - Posts: 79
Im using sc.GetMarketDepthFromChart(), to display the MNQ depth, on an NQ chart. However, this only seems to display the DOM at the last bar index -1. Its not "live", as in keeping up with the DOM on the current chart. Its always one "bar" behind.
Is there any method to retrieve live DOM from one chart to another?
Similar to the sc.GetBidMarketDepthEntryAtLevel(DepthEntry, Level) , but for another chart.
If not, can you add it as a feature?
Also...NumOrders doesn't seem to be accesible in MarketDepth historical either, even though it is there?? I can't historically display it for some reason.
Date Time Of Last Edit: 2026-01-31 00:22:40
