Date/Time: Wed, 25 Nov 2026 22:50:10 +0000
How to Plot Custom SCID File Data on Chart?
View Count: 1609
| [2026-01-30 21:09:09] |
| User396 - Posts: 61 |
Hello, I have a custom ACSIL study (computationaly heavy) that calculates values and writes them to an SCID file using sc.RelayTradeUpdate(). The SCID file is being created and contains data. Problem: The chart shows no bars/values. The SCID file exists with data, but I cannot get Sierra Chart to display it. What I need: A way to open/display an existing SCID file as a chart - without recalculating all the historical values again. Questions: What symbol/chart settings are required to display data from a custom SCID file? Is sc.RelayTradeUpdate() the correct function for this use case, or should I use something else? Do I need to configure the symbol as "No Data Feed" in Global Symbol Settings? The data is already computed and saved - I just need Sierra Chart to read and display it. Thank you, user396 Date Time Of Last Edit: 2026-01-30 21:29:52
| [2026-02-03 20:30:59] |
Hi John, Is this possible? Please let me know. thank you, user396 |
| [2026-02-04 18:19:49] |
| Sierra_Chart Engineering - Posts: 25484 |
We do not know what the problem is in your case. We do have this documentation: Intraday Data File Format This is outside the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
