Date/Time: Wed, 25 Nov 2026 22:42:27 +0000
times and slaes window is always messed
View Count: 428
| [2026-01-30 18:39:39] |
| User30743 - Posts: 399 |
how to LOCK times sales window to a particular position on a screen? Anytime I open a chartbook, where is TS window, it is on a compeltely different position as it was when i closed it, even when I switch chartbooks it just jumps somewhere. What is wrong with it? I tried so many options - attached or detached or with or without title bar.. I have literally spent hours trying to set it up, but it never stays where it should stay. Why is that? What am I doing wrong? |
| [2026-01-30 19:30:47] |
| Sierra_Chart Engineering - Posts: 25484 |
We want you to update Sierra Chart to the current version. Instructions: Software Download: Fast Update See if this makes any difference for you regarding this issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
