Date/Time: Wed, 25 Nov 2026 22:50:08 +0000
ACSIL Subgraph vs sc.UseTool Drawing/Rendering Engines
View Count: 650
| [2026-01-30 18:27:01] |
| User688525 - Posts: 403 |
Hello Sierra Engineering, Are different drawing/rendering engines used for ACSIL subgraph and sc.UseTool drawings? For example, a dashed line via subgraph looks different to the same with sc.UseTool? Thank you |
| [2026-01-31 21:31:54] |
| Sierra_Chart Engineering - Posts: 25484 |
We do not know what is meant by "engine". We really do not like that word in software. An engine involves, a chemical reaction to convert that to a moving force. All graphics in Sierra Chart are done either through the graphics device interface of windows, or OpenGL. OpenGL can be enabled or disabled. A dashed line will look different because Subgraphs, are drawn, one bar at a time and not a continuous line spanning many bars as compared to Chart Drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-31 21:32:39
