Date/Time: Wed, 25 Nov 2026 22:42:22 +0000
export volume at price data to txt file
View Count: 1427
[2026-01-30 15:39:07]
userlk0m - Posts: 3
When I export the price data to text file (including studies), volume at price values from the Numbers or VbP studies do not export.
How can I export them?
[2026-01-30 16:38:23]
You can not export the Numbers Bars data.
For VbP data, refer to the following:
Spreadsheet Study Inputs: Output Volume at Price Data
[2026-01-30 16:41:11]
userlk0m - Posts: 3
I ended up using code for it, I'll post it here for anyone else trying to do the same:
#include "sierrachart.h"
#include <fstream>
#include <cstdio> // snprintf
SCDLLName("Per Bar VAP Exporter")
SCSFExport scsf_VAP_Export(SCStudyInterfaceRef sc)
if (sc.SetDefaults)
sc.GraphName = "Export Per-Bar VAP (Price,Volume Pairs)";
sc.AutoLoop = 0;
sc.UpdateAlways = 0;
return;
// Overwrite each run. Change to std::ios::app to append.
std::ofstream file("vap_export.txt", std::ios::trunc);
if (!file.is_open())
return;
file << "DateTime,BarIndex,VAP\n";
for (int bar = sc.UpdateStartIndex; bar < sc.ArraySize; ++bar)
const int count = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(bar);
if (count <= 0)
continue;
// DateTime string: YYYY-MM-DD HH:MM:SS
int Y=0, M=0, D=0, h=0, m=0, s=0;
sc.BaseDateTimeIn[bar].GetDateTimeYMDHMS(Y, M, D, h, m, s);
char dt[32];
std::snprintf(dt, sizeof(dt), "%04d-%02d-%02d %02d:%02d:%02d", Y, M, D, h, m, s);
// Start row: quote the bracket field so commas inside don't break CSV
file << dt << "," << bar << ",\"[ ";
for (int i = 0; i < count; ++i)
s_VolumeAtPriceV2* p = nullptr;
if (!sc.VolumeAtPriceForBars->GetVAPElementAtIndex((unsigned int)bar, i, &p) || p == nullptr)
continue;
const double price = (double)p->PriceInTicks * sc.TickSize;
const int vol = p->Volume;
file << "(" << price << "," << vol << ")";
if (i != count - 1)
file << ", ";
file << " ]\"\n";
file.close();
Date Time Of Last Edit: 2026-01-30 16:41:54
