Date/Time: Mon, 02 Nov 2026 07:28:24 +0000
zigzag slowing down PC
View Count: 1252
| [2014-10-21 20:13:17] |
| jivetrader - Posts: 410 |
hi, the zigzag study is slowing down my machine quite a bit. i have it set to use ask-bid volume diff. slowdown is most notable when editing the study, then hitting Apply or OK. can you recommend any tips to improve the situation. e.g. closing other programs (RAM usage) or is it more of a cpu issue, or something else thanks |
| [2014-10-21 21:37:40] |
Potentially this study could use high CPU usage when it is initially being calculated. But not during real-time updating.
| [2014-10-21 22:01:30] |
yes that is my experience. so only a faster cpu will improve this?
| [2014-10-21 22:29:53] |
The proper solution in this kind of case is to reduce the Days to Load in Chart >> Chart Settings.
