Date/Time: Wed, 25 Nov 2026 22:42:23 +0000
[Programming Help] - Detection of volume increase area
View Count: 497
| [2026-01-29 10:12:58] |
| xlogic314 - Posts: 17 |
Can l set “if” condition on a volume area ? For example, on session if volume increase from between 100-200 to 500 and more highlight this area. Also l want to get this information at a time range. İf volume increae 500 in 5 seconds. Highlight area.
Date Time Of Last Edit: 2026-01-29 10:19:28
| [2026-01-29 15:16:10] |
This definitely can not be done using the built-in tools. You would have to see if you can do this in a custom study. Refer to the following: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
