Date/Time: Wed, 25 Nov 2026 22:42:18 +0000
Chart DOM discrepancy
View Count: 386
| [2026-01-29 02:13:49] |
| Topdog33 - Posts: 44 |
Hi John So I’m trading ESH 26 CME on the DOM and one contract for 30 points should equal about $1500 profit but even with 14 contracts, I’m just testing it out. It’s only $300 profit for 30 points lol what am I doing wrong? Is there something with the settings? Kindly advise please I can’t trade like this. |
| [2026-01-29 02:14:26] |
And I have the data feeds that set at sc
| [2026-01-29 14:58:47] |
Check the setting for "Chart >> Chart Settings >> Symbol >> Currency Value per Tick". Make sure this is set correctly for ES - it should be 12.5. Where exactly are you viewing the Profit/Loss? The Currency Value per Tick comes from different locations depending on whether you are viewing it on the Chart and the Trade Window for that chart versus the Trade Activity log. If you are using a Trade and Current Quote Symbol for that chart, then you need to ensure that the "Currency Value per Tick" is set to the value for the actual traded symbol. Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
