Date/Time: Wed, 25 Nov 2026 22:42:24 +0000
Fixed time VWAP error
View Count: 449
[2026-01-28 16:14:37]
User415474 - Posts: 1
Hi. Basically what i want to do is set up 2 separate vwap charts, each chart with a 1 hour vwap, but set at different times, so when one is starting, i have the other one stil developed (To eliminate the need to wait untill the vwap develops). But i have a problem. I set a vwap to start at 9:30, with a 60 minutes period, but only the first vwap resets at 10:00, it only lasts 30 minutes, and then the next ones are 1 hour each. I tried setting it to 10:30, but the same happens, it resets at 11, only 30 minutes. The other chart which is set to start at 10:00, seems to work fine, each one resets after 1 hour.
What could be the problem here?
[2026-01-28 16:17:40]
Please get us an image of your settings for the VWAP study.
