Date/Time: Wed, 25 Nov 2026 22:42:16 +0000
Drawing Comments Under Right Aligned Profiles
View Count: 355
[2026-01-28 14:51:45]
User753526 - Posts: 87
Is there a way to indent the comments on any chart drawings that are right aligned to prevent them from being overlapped by any Volume Profiles that are aligned to the far right of the chart?
[2026-01-28 15:38:24]
We are not certain what exactly you are looking for, but for some drawings that are controls on where the text is placed. You would have to look at the specific drawing and see what it is available and if the options give you what you are looking for. Otherwise, there are no other settings that control how the text is placed for a drawing.
[2026-01-28 15:42:54]
As an example. Where I place the arrow here the price of the horizontal ray disappears beneath the right aligned profiles.
In the Rectangles I have added 30 blank spaces to move the text where I can see it.
Is there a setting to prevent overlap of drawing text & these profiles?
imageeg.png / V - Attached On 2026-01-28 15:41:37 UTC - Size: 25.95 KB - 180 views
[2026-01-28 15:46:32]
There is no setting to prevent overlap.
