Date/Time: Wed, 25 Nov 2026 22:42:29 +0000
Where is the DOM configuration in the computer file?
View Count: 377
[2026-01-28 13:38:34]
Jimmyz83 - Posts: 62
My DOM changed colors on its own when opening up. I have logged out and back in and still did not change back. I have different computer files for each prop firm I use and the other files did not change. So I want to pull the specific DOM color or the entire DOM file from another file and replace it into another which has changed. My DOM set up is complicated and do not want to try to set it up again. Can you help.
[2026-01-28 15:29:37]
How you go about this depends on how you have the DOM setup to handle the colors - whether the DOM is setup to use Global Graphics or if it is setup to use Chart Specific Graphics. Refer to the following setting that controls this:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
Which is why our first question is whether it is possible that this got changed which caused the issue you are having. If so, then changing the setting would solve your issue.
If that does not solve the issue, then we need to know how you have the DOMs setup for that setting. Let us know how it is set so we can then give you the proper instructions.
Also, we need to understand what you mean by "I have different computer files for each prop firm I use...". Do you have different installations for each prop firm? Or are you actually changing files?
