Date/Time: Wed, 25 Nov 2026 22:42:05 +0000
Trading MES on ES DOM with cross trading
View Count: 797
| [2026-01-27 22:00:58] |
| User547080 - Posts: 2 |
Hey, I want to be able to use the ES DOM for my analysis and see all the data for ES but trade MES contracts off of the ES dom. I looked at other support tickets for this and changed my settings to the correct order but when i place my order on the ES dom it still buys the es contract and mes contract at the same time and i just want the mes to go through. |
| Attachment Deleted. |
| [2026-01-27 23:06:52] |
| User719512 - Posts: 548 |
Are you sure it's trading ES? Review the trade log to be sure. For MES you'd want to change Currency Value Per Tick (2nd image) from 12.5 to 1.25.
| [2026-01-28 14:56:13] |
What User719512 states is correct. We need to know why you state that you are getting orders for both ES and MES. Refer to the following regarding the Currency Value per Tick when using a "Trade and Current Quote Symbol": Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
