Date/Time: Wed, 25 Nov 2026 22:42:29 +0000
Linux and NTP
View Count: 456
[2026-01-27 15:21:24]
User165981 - Posts: 66
I'm trying to make the move to Linux Mint. So far everything seems to be working but I see the following in the logs:
2026-01-27 10:12:52.337 | NTP Client | Sending packet to ntp_usmw.sierrachart.com:11497
2026-01-27 10:13:22.349 | NTPClient (4) | Ignored Send call. Socket is not connected.
What is this?
Thanks!
[2026-01-27 17:03:40]
That is related to the Network Time Protocol, which sets the clock for your system. We are not certain what those specific errors are coming from - it may be simply that you are doing this on an emulator, which has a problem with it.
But, these are nothing to be concerned with, as they do not impact the software itself. Refer to the following regarding NTP, so you can turn it off if you want:
Network Time Protocol Client
[2026-01-28 06:52:16]
Sierra_Chart Engineering - Posts: 25484
We will have to look into this later. There is some problem with UDP socket implementation Sierra Chart uses on Wine.
