Date/Time: Wed, 25 Nov 2026 22:42:28 +0000
Further Stops and targets to existing trade
View Count: 393
| [2026-01-26 17:26:58] |
| User237783 - Posts: 3 |
Hello, how can I add further targets to an active trade with existing stops and targets that run through the same OCO group? In practical terms: a target is filled, and further targets and stops are adjusted in quantity. Thanks for answering |
| [2026-01-26 21:14:01] |
If you want to add additional attached orders to an existing position, then you would setup the Attached Orders and use one of the Order Types of "Send Attached Orders by Position/Price". Refer to the following: Order Types: Send Attached Orders - Position/Price If you are wanting to add to an existing position then refer to the "Scale In" option: Attached Orders: Scaling In If you are wanting to remove from an existing position (close out part of a postion) and want the existing attached orders to update with respect that removal, then refer to the information for "Scale Out": Attached Orders: Scaling Out For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
