Date/Time: Wed, 25 Nov 2026 22:42:31 +0000
Is Trading EUREX/CQG and CME/Teton by Data Feed Denali with one instance possible
View Count: 479
[2026-01-26 09:24:34]
User807393 - Posts: 5
Hello, I would like to trade EUREX/CQG and CME/Teton with one instance only using AMP as a broker for EUREX routing via CQG and CME routing via Teton. Data Feed in general should be by Denali. Do you have any idea how I can apply this with AMP Future Broker and how it can be managed with Sierra Chart software? Or do I need two instances for trading both CME/Teton and EUREX/CQG by AMP at the same time?
[2026-01-26 18:02:11]
You need two separate installations of Sierra Chart to do this. One to connect to CQG and one to connect to Teton. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Another option would be to stop using the Teton Order Routing and just use CQG for order routing for both the CME Group and EUREX.
[2026-01-26 19:09:59]
Thanks, for the information. When I install two times Sierra chart, can I connect both installations with the same account from AMP?
[2026-01-26 21:27:16]
It depends on the order routing service you are using. You can have multiple installations connecting to the same account that uses Teton Order Routing. But if you are using CQG or Rithmic, then those systems do not allow for multiple connections, so you can not do this.
But if you are setup to use CQG for EUREX and Teton for CME Group, then this will be setup as two different accounts by AMP, so this would not apply in this case.
