Date/Time: Wed, 25 Nov 2026 22:42:32 +0000
All my internet is freezing when I download current historical data on my computer
View Count: 357
| [2026-01-25 10:11:18] |
| GravisHTG - Posts: 321 |
Am I the only one having this problem ? As a test , I delete and redownload data from ES - and then click on my youtube to refresh - and then its not responding... Sierra chart only use 2.5mbps of my bandwith , and I have 80 mbps. I wonder what is happening , i try to debug it with gemini , he ask me to do a lot of different config in the network card , but none of that works. Is their a way to reduce the load on the network card when we are updating our data. Just update my Realtek adapter , its better now at bringing back the connection , but still when under SC data load - it freeze all other connectivity to my computer. EDIT - I fix it by reinstalling everything + put sierra chart on his on SSD Date Time Of Last Edit: 2026-02-01 07:05:25
| [2026-01-25 19:27:35] |
| Sierra_Chart Engineering - Posts: 25484 |
We cannot help with this. This is a system specific issue. It has nothing to do with Sierra Chart.
| [2026-01-25 19:45:10] |
| User719512 - Posts: 548 |
To monitor and optimize my system, I installed the following tools: - HWiNFO64 - LatencyMon - CrystalDiskInfo Always good to check disk firmware versions, BIOS updates, OS updates, etc. From the above, you can gather more info on resource usage on your system. |
