Date/Time: Tue, 10 Nov 2026 17:33:10 +0000
Sierra Chart Connection Error - DTC Socket - Windows 10061
View Count: 442
| [2026-01-24 01:03:28] |
| PA172 - Posts: 4 |
Hello, I ran through two weeks of evaluations without any issues. I just signed up to Sierra Charts and the second day in a row now I'm having connection issues. I don't think it's on my end as I was running the SIM for two weeks downloading data. I'm also going to 'Send for Analysis'. I would also like to add that this appears to be very intermittent as I just check this and was able to get SC to connect. 2026-01-23 19:41:02.993 | Trading Evaluator | Connecting to the server tradesimulation4.sierracharts.com. Port 11096 2026-01-23 19:41:02.993 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-23 19:41:02.994 | DTC Client socket (1) | New receive buffer size: 0 2026-01-23 19:41:02.994 | DTC Client socket (1) | Connecting to IP: 69.39.70.246. 2026-01-23 19:41:05.660 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. * 2026-01-23 19:41:05.660 | DTC Client socket (1) | CloseSocket call. 2026-01-23 19:41:05.660 | Trading Evaluator | Failed connections: 47 2026-01-23 19:41:05.660 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-23 19:41:05.660 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-23 19:41:05.660 | DTC Client socket (1) | Closed. 2026-01-23 19:41:05.671 | DTC Client socket (0) | CloseSocket call. 2026-01-23 19:41:05.671 | Trading Evaluator | Disconnected. 2026-01-23 19:41:05.671 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-23 19:41:07.680 | 2026-01-23 19:41:07.680 | Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 2026-01-23 19:41:07.685 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-23 19:41:07.686 | DTC Client socket (1) | New receive buffer size: 0 2026-01-23 19:41:07.686 | DTC Client socket (1) | Connecting to IP: 64.152.155.17. 2026-01-23 19:41:28.716 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2026-01-23 19:41:28.716 | DTC Client socket (1) | CloseSocket call. 2026-01-23 19:41:28.716 | Trading Evaluator | Failed connections: 48 2026-01-23 19:41:28.716 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-23 19:41:28.716 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-23 19:41:28.716 | DTC Client socket (1) | Closed. 2026-01-23 19:41:28.732 | DTC Client socket (0) | CloseSocket call. 2026-01-23 19:41:28.732 | Trading Evaluator | Disconnected. 2026-01-23 19:41:28.732 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. |
| [2026-01-24 01:12:02] |
| PA172 - Posts: 4 |
Somehow Sierra Charts was able to log in and I was able to start the SIM again. Then it lost the connection again with the following Message Log: 2026-01-23 20:07:46.530 | Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 2026-01-23 20:07:46.531 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-23 20:07:46.532 | DTC Client socket (1) | New receive buffer size: 0 2026-01-23 20:07:46.532 | DTC Client socket (1) | Connecting to IP: 64.152.155.17. 2026-01-23 20:07:54.331 | ESH26[M] 5 Min #5 | Reloading chart. 2026-01-23 20:07:54.335 | ESH26[M] 1 Min #3 | Reloading chart. 2026-01-23 20:07:54.338 | ESH26[M] 30 Sec #1 | Reloading chart. 2026-01-23 20:07:54.341 | ESH26[M] 15 Sec #4 | Reloading chart. 2026-01-23 20:07:54.360 | ESH26[M] #2 | Reloading chart. 2026-01-23 20:07:54.897 | ESH26[M] 5 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-01-23 20:07:54.903 | ESH26[M] 5 Min #5 | Chart data loading complete. 2026-01-23 20:07:54.904 | ESH26[M] 1 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-01-23 20:07:54.913 | ESH26[M] 1 Min #3 | Chart data loading complete. 2026-01-23 20:07:54.916 | ESH26[M] 30 Sec #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-01-23 20:07:54.920 | ESH26[M] 30 Sec #1 | Chart data loading complete. 2026-01-23 20:07:54.960 | ESH26[M] 15 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-01-23 20:07:54.965 | ESH26[M] 15 Sec #4 | Chart data loading complete. 2026-01-23 20:07:55.672 | ESH26[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-01-23 20:07:55.675 | ESH26[M] #2 | Chart data loading complete. 2026-01-23 20:07:56.228 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2026-01-23 20:07:56.228 | DTC Client socket (2) | CloseSocket call. 2026-01-23 20:07:56.228 | Delayed Data Feed | Failed connections: 1 2026-01-23 20:07:56.228 | DTC Client socket (0) | CloseSocket call. 2026-01-23 20:07:56.228 | Delayed Data Feed | Disconnected from the server. 2026-01-23 20:07:56.228 | Delayed Data Feed | Data feed disconnected. Will reconnect in 5 seconds. 2026-01-23 20:07:56.229 | DTC Client socket (2) | Closed. 2026-01-23 20:08:01.218 | Delayed Data Feed | Connecting to the server ds32.sierracharts.com. Port 10043 2026-01-23 20:08:01.223 | DTC Client socket (2) | Creating socket. 2026-01-23 20:08:01.223 | DTC Client socket (2) | New receive buffer size: 0 2026-01-23 20:08:01.223 | DTC Client socket (2) | Connecting to IP: 69.39.70.248. 2026-01-23 20:08:07.582 | DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. * 2026-01-23 20:08:07.582 | DTC Client socket (1) | CloseSocket call. 2026-01-23 20:08:07.582 | Trading Evaluator | Failed connections: 1 2026-01-23 20:08:07.582 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-23 20:08:07.582 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-23 20:08:07.583 | DTC Client socket (1) | Closed. 2026-01-23 20:08:07.599 | DTC Client socket (0) | CloseSocket call. 2026-01-23 20:08:07.599 | Trading Evaluator | Disconnected. 2026-01-23 20:08:07.599 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. |
| [2026-01-24 01:33:16] |
| Sierra_Chart Engineering - Posts: 25407 |
There was a network issue, in our infrastructure, affecting intermittently connections, starting around 4 PM Eastern today, but it is resolved.
