Date/Time: Wed, 25 Nov 2026 22:42:29 +0000
New installation
View Count: 427
[2026-01-23 09:38:04]
User499894 - Posts: 67
Hi, my SC installation consists of main instance + 3 separated ones; I would like to replicate it (in the same SSD) exactly as it is now (giving it a new name and putting the right paths in Global settings>General settings). Do I have to follow what is explained in: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation or can I simply copy/paste the SierraChart folder?
[2026-01-23 16:19:49]
You can copy and paste the entire folder and then update a couple of items. Follow these instructions for this:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System
