Date/Time: Wed, 25 Nov 2026 22:42:29 +0000
Load Bid/Ask option missing for MES continuous contract after Update From Server
View Count: 375
[2026-01-23 04:16:38]
User122704 - Posts: 15
Sierra Chart Version: 2813
Service: Denali Exchange Data Feed
Symbol: MES (continuous MES##_FUT_CME) and MNQ
Chart Type: 1-minute Intraday
Issue:
The "Load Bid/Ask Update Only Intraday Records" option is missing from the Chart Settings → Symbol tab for MES/ MNQ futures charts. It does not appear even after creating a new chart, updating from server, or resetting to default.
I have already:
- Set Global Settings → Symbol Settings for MES##_FUT_CME → clicked "Update From Server"
- Set Intraday Data Storage Time Unit = 1 Tick
- Set Record Interval = 1 Tick
- Deleted data and re-downloaded
- Restarted Sierra Chart
But the option still does not show up in per-chart Symbol settings.
Attached screenshot of Global Symbol Settings window for MES##_FUT_CME showing no bid/ask related options.
This prevents live intrabar bid/ask updates in my custom ACSIL study so provisional dots only appear at bar close, not mid-bar.
Please advise how to enable per-tick bid/ask recording for MES and or MNQ continuous contracts.
Very Respectfully
Kelly Alton
imageMES Global Symbol Settings_NO Load Bid Ask Option Available.jpg / V - Attached On 2026-01-23 04:13:24 UTC - Size: 88.66 KB - 139 views
[2026-01-23 11:05:12]
User431178 - Posts: 910
Chart >> Chart Settings >> Chart Data >> Load Bid/Ask Update Only Intraday Records
Chart Settings: Load Bid/Ask Update Only Intraday Records (Chart >> Chart Settings >> Chart Data menu)
No that is not the cause, it is certainly a problem with how the study is coded.
Even without the Bid/Ask Update Only Intraday Records, the bid/ask is updated/recorded when each trade occurs.
