Date/Time: Wed, 25 Nov 2026 22:42:33 +0000
dtc message size
View Count: 600
[2026-01-21 06:01:04]
seandunaway - Posts: 399
just fyi, sierrachart as a dtc client is padding the message size more than the existing documentation
Authentication and Connection Monitoring Messages: ENCODING_REQUEST [s_EncodingRequest structure] Client >> Server
<Buffer 14 00 06 00 08 00 00 00 00 00 00 00 44 54 43 00>
1/20/2026, 9:51:28 PM 10.211.55.3 --> {"Size":20,"Type":"EncodingRequest","ProtocolVersion":8,"Encoding":"Binary","ProtocolType":"DTC"}
Type: 6,
ProtocolVersion: 8,
Encoding: 0,
ProtocolType: 'DTC'
are all the messages over the wire potentially unpacked?
[2026-01-22 16:38:53]
Sierra_Chart Engineering - Posts: 25484
We do not understand this question. There is no padding in that data structure. None.
[2026-01-22 21:26:23]
encoding request, for example is documented as being 16 bytes. my client also sends 16 bytes with the same struct but i was confused when sierrachart the client sends size 20 with 4 extra bytes ..."DTC\0 \0\0\0\0"
14 00 06 00 08 00 00 00 00 00 00 00 44 54 43 00 00 00 00 00
if it's similar on other messages that could potentially be a 10-20% savings in bandwidth
Date Time Of Last Edit: 2026-07-04 15:55:35
[2026-01-23 20:40:25]
The extra four bytes are the header. The length of the message and the type.
And the way the bandwidth is managed with the DTC protocol is to use LZ4 compression. Sierra Chart does support this. With this compression the space is reduced anywhere from about 40% to 80%.
Date Time Of Last Edit: 2026-01-24 18:17:52
