Date/Time: Wed, 25 Nov 2026 22:26:20 +0000
Can't Resize or move Trade Window
View Count: 517
[2026-01-21 02:44:54]
User950109 - Posts: 8
When I open my chartbook, the trade window opens on another monitor and I cannot move it or resize it. It is stuck at the top of the screen.
imagesc window.png / V - Attached On 2026-01-21 02:43:01 UTC - Size: 1.55 MB - 185 views
[2026-01-21 15:40:43]
That is a wonderful Microsoft Windows feature.
One option is to select "Chart >> Reset Child Windows". This should move the Trade Window to a location where you can access it and move it where you want.
Alternatively, you can do an Internet search using terms like the following "move window with title bar off screen". You will find the information for how to move it in the results.
[2026-01-21 17:04:38]
Sierra_Chart Engineering - Posts: 25484
Go through the instructions here:
Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM
You definitely need to reset the child windows.
Date Time Of Last Edit: 2026-01-21 17:04:50
[2026-01-21 17:19:34]
I was able to close them using your instructions, thanks guys!
