Date/Time: Wed, 25 Nov 2026 22:26:27 +0000
In replay mode only my first position is set with tp and sl
View Count: 326
| [2026-01-21 02:28:20] |
| Ilovenq - Posts: 1 |
Hi; I have an issue when im on replay mode; my first position is set correctly with tp and sl that i can change directly on chart. But when this position close and i open an another one it's just appearing in chart without and sl. I tried to flattern and cancel all position before but nothing is fixed. I just can't have next positions with tp and sl. All of my positions are opened manually btw. Thanks in advance for your help! Date Time Of Last Edit: 2026-01-21 02:31:47
| [2026-01-21 15:36:34] |
You will need to go through the process of troubleshooting this, as there is no obvious reason for this to occur. First, after you place the first order and before you place the next one, make sure the option for "Use Attached Orders" is enabled on the Trade Window. Refer to the following: Basic Trading and the Trade Window: Main/C >> Use Attached Orders It can also be helpful to turn on confirmations, this way you can see the actual orders that are going to be placed and see if the TP and SL are actually there, but at some odd price. Refer to the following: Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) One thing we thought of while writing this, is that if you are using different charts, then these will have different setups in the Trade Window. So this could be the reason why one order has the TP and SL, but the other does not. Refer to the following: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
