Date/Time: Wed, 25 Nov 2026 22:26:20 +0000
Study Settings Missing in Latest Sierra Version
View Count: 527
[2026-01-20 20:32:33]
Sjz1128 - Posts: 3
I just upgraded my SierraChart version from 2813 to 2866. I use a custom indicator that I coded, but it's now missing several important settings. Are there new limits in the most recent version of Sierra? If so, how can I get around this? I've been using this indicator for years. Thank you!
Sam Zell
[2026-01-20 20:41:31]
User719512 - Posts: 548
What does your code look like where you declare your inputs?
Which ones are missing? Random, or all after some given input id?
Are they contiguous?
SCInputRef Input_a = sc.Input[0];
SCInputRef Input_b = sc.Input[1];
SCInputRef Input_c = sc.Input[2];
SCInputRef Input_d = sc.Input[3];
or are they more like:
SCInputRef Input_b = sc.Input[12];
SCInputRef Input_c = sc.Input[34];
SCInputRef Input_d = sc.Input[42];
[2026-01-20 20:59:46]
Sjz1128 - Posts: 3
they are contiguous. i am using 83 inputs. although i cannot see all of them in the ui, the indicator is still fully functioning with default settings
[2026-01-21 18:42:07]
Sierra_Chart Engineering - Posts: 25484
In the sc.SetDefaults code block, add this line:
sc.ProcessStudyUnsetInputs=1;
This will resolve the problem.
If you still have a problem we need to get the study function to test.
Date Time Of Last Edit: 2026-01-21 18:42:45
