Date/Time: Wed, 25 Nov 2026 22:26:24 +0000
Question about sc.ChangeChartReplaySpeed()
View Count: 410
| [2026-01-20 15:03:05] |
| Tony - Posts: 738 |
Hi, Right now, this function only has effect during replay, not sure if it's a WINE issue, or just how it works, if so, I am wondering if it is possible to have effect anytime? Thanks so much. |
| [2026-01-20 15:17:31] |
| Sierra_Chart Engineering - Posts: 25484 |
This could not possibly be related to the operating system. Open the replay control panel: Chart >> Replay Chart >> Replay Chart. Do you see the updated speed display there? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-20 18:40:19] |
| Tony - Posts: 738 |
I am writing an ACSIL code and using + and - keys to increase or decrease replay speed number, during replay it works fine, I see the replay speed number updated in the replay control panel. Let's say the replay speed is 20, and eventually it catches up with the live data, then replay stops, as I expected, but after that, the speed number in control panel will not change when I hit + or - key, until I replay the chart again later. In my ACSIL, I was actually trying to set the replay speed to 1 whenever chart is not replaying. But the function has no effect Date Time Of Last Edit: 2026-01-20 18:41:31
| [2026-01-21 18:40:05] |
Without going into a lot of details, the Replay Speed, cannot be changed when a replay is not running.
| [2026-01-21 19:22:22] |
| Tony - Posts: 738 |
Thanks so much for your confirmation, I will find a workaround. I don't believe anything needs to be changed @ ACSIL.
Date Time Of Last Edit: 2026-01-21 19:23:17
