Date/Time: Wed, 25 Nov 2026 22:50:15 +0000
Current traded Ask minus Bid Vol colors
View Count: 680
| [2026-01-19 14:47:10] |
| User165981 - Posts: 66 |
I see where to change the color of the value. Is there a way to change the color of the volume bar? Thanks |
| [2026-01-19 16:32:02] |
| Sierra_Chart Engineering - Posts: 25484 |
Yes it is this color setting: Chart DOM Current Traded Ask Volume Bid Volume Difference Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-19 16:36:32] |
I didn't clarify as well as I should have. I wnated to change the bar color based on whether it's positive or negative. Is that possible? Thanks again |
| [2026-01-19 17:33:05] |
| Sitting Bull - Posts: 13 |
Hello, I'm also interested with this feature !
| [2026-01-19 20:24:15] |
We will add an additional color setting for volume bars. You will be able to configure the volume bars color for positive and negative.
| [2026-01-19 20:30:03] |
Thank you!
| [2026-02-05 01:00:39] |
Was this ever implemented? I didn't see where it could be changed. Thanks |
| [2026-02-07 00:06:41] |
Not implemented yet but we will do this.
