Date/Time: Wed, 25 Nov 2026 22:26:25 +0000
Attached Orders – Targets modified before fill are reset at execution (Live only)
View Count: 477
| [2026-01-19 14:15:27] |
| User853826 - Posts: 1 |
Hello, I am experiencing an unexpected behavior with Attached Orders in Sierra Chart and would like your assistance to identify the cause. Context: Trading via DOM / Chart Trade with Attached Orders enabled Entry order: Limit order Initial Attached Order template: TP1 = 30 ticks, TP2 = 30 ticks, SL = 25 ticks Steps to reproduce: I place a limit order with Attached Orders enabled Before the order is filled, I manually adjust TP1 and TP2 (e.g. TP1 = 50 ticks, TP2 = 100 ticks) When the entry order is filled, TP1 and TP2 automatically revert to the original template values (30 / 30) Important notes: This behavior occurs only in Live trading In Simulation mode, the manually adjusted targets are preserved at fill This workflow was working correctly until a few weeks ago I suspect a global setting change or a recent Sierra Chart update may be responsible Question:Could you please confirm whether there is a setting (global or chart trade) that forces the reapplication of the Attached Order template at the time of order fill, and which setting should be adjusted to preserve target modifications made before execution? Thank you in advance for your support. Best regards, |
| [2026-01-20 07:07:39] |
| Sierra_Chart Engineering - Posts: 25484 |
There are various possible reasons for the change in the Attached Order settings. You could be using Trade Window linking. You could be changing the Trade Window configuration. A Spreadsheet Trading study could be changing them An ACSIL study could be changing them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-20 07:07:49
