Date/Time: Wed, 25 Nov 2026 22:26:25 +0000
Error on DLL after building custom study.
View Count: 1871
| [2026-01-19 02:26:49] |
| smmrai - Posts: 1 |
Ive made it before, build studies with cpp files build them remotly and local and worked just fined. Somehow, ive started to get this error, build of the cpp file succeed, but every time i go F6 add custom study, message log opens up telling that dll is empty and no functions in it. Ive even formated my PC installed a fresh Windows 11, installed Visual Studo, Desktop Environment C++, and even after all that i still cant get my sierra to read the dll. Windows firewall antivirus checked, sierra dll files deleted on C>SierraChart>Data everysingle time. I dont know what to do, its been 3 days that im on it. Tried all. Builds always work out, remote or local, but anytime F6, add custom study message log pops up and i dont see my study on the list. |
| [2026-01-19 20:47:00] |
Is the DLL in the 'Data' folder under your main Sierra Chart installation folder? Does the DLL end in _64.dll? When you select "Analysis >> Studies", check your "Message Log" and see if the DLL is listed as being found in the Message Log. If it is, then you should be able to select the study in that file and use it. After you try to add the study and if you have a problem, then get us your Messag Log so we can see what it states. Follow these instructions to get us your Message Log: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
