Date/Time: Wed, 25 Nov 2026 22:26:26 +0000
setting teamplate
View Count: 393
| [2026-01-18 19:40:18] |
| User748898 - Posts: 1 |
Hello, please tell me, I have two chartbooks, in one a template was created, it is on the left, and when duplicating the chart, and changing the symbol on the other, it changes in the first one too, how can I fix this, I used the GPT chat, but it did not help me
| [2026-01-19 20:04:39] |
You must have chart linking setup in that "Template", which is then copying over. You will want to remove the linking options (or at least the Symbol option). Refer to the following: Chart Settings: Linking For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
