Date/Time: Wed, 25 Nov 2026 22:26:30 +0000
Floating Control bars always visible
View Count: 366
| [2026-01-18 17:52:12] |
| User499894 - Posts: 67 |
Hi, since upgrading to version 2862 if I minimize the main SC window, a sub-instance window or a detached chart window, all FLOATING Control bars stay visible on the desktop in their original position; this did not happen before the upgrade, is there any solution? (Open GL not enabled) Thanks
| [2026-01-18 19:33:22] |
| Sierra_Chart Engineering - Posts: 25484 |
We will check on this. We were not aware of this.
