Date/Time: Wed, 25 Nov 2026 22:26:25 +0000
date format
View Count: 364
[2026-01-18 09:44:13]
SafSaf - Posts: 160
alright lads, is there a way to globally change the date format from mm/dd/yy to dd/mm/yy
[2026-01-19 19:43:55]
No, there is not a way to change this.
Although Sierra Chart has the date displayd as YYYY-MM-DD, and you can usually enter the date in any format you want and it will adjust accordingly.
