Date/Time: Wed, 25 Nov 2026 22:26:23 +0000
[Programming Help] - ACSIL for specific operations
View Count: 895
| [2026-01-17 18:39:30] |
| User925540 - Posts: 147 |
Hi I use these operations frequently and thinking of grouping them into a custom ACSIL and wanted to know which of them are accessible via sc. and how to access them 1) Clear Alert Sound Queue 2) Erase All Text 3) Erase NonText Drawings 4) Erase All Drawn Volume Profiles 5) Reset Scale All Charts 6) Reset Bar Size/Spacing/Scale 7) Scroll All Charts To End 8) Goto End of Chart 9) Recalculate All Charts 10) Clear Recent File List 11) Clear Trade Orders Simulation and Data Thank you. |
| [2026-01-17 19:16:50] |
| User719512 - Posts: 548 |
Best advice I have is read all of sierrachart.h (and other headers). Also use VS Code and search headers and Sierra Sample Source code. Then read all of ACSIL Interface Members - Introduction For example, you can find this: ACSIL Interface Members - Variables and Arrays: sc.ScrollToDateTime which may or may not work for your #7/8, however END and Ctrl+END do these. Your #2/3 can be done via ACSIL. #4 may not be able to differentiate between "drawn" and added to chart as a study. I would think #9 is not needed since if you recalculate a given chart, Sierra will recalculate any charts that depend on it. The others should not be involved. This is free advice and worth what you are paying for it. Caveat emptor. |
