Date/Time: Wed, 25 Nov 2026 22:26:27 +0000
ReplayStatus changes in v2865
View Count: 496
| [2026-01-17 18:27:39] |
| User719512 - Posts: 548 |
Noticed enum ReplayStatus was changed in v2865. I know the documentation usually lags the Sierra code/headers, but there is a possibility of an unintended side effect with introducing REPLAY_STATUS_UNSET. int IsReplayRunning() { if(ReplayStatus != REPLAY_STOPPED) return 1; return 0; } It is unclear if/when REPLAY_STATUS_UNSET is set/used, but seems to me this would break IsReplayRunning(). I would like to think REPLAY_STATUS_UNSET is not needed since if the replay is not running or paused, then it must be in the stopped state. |
| [2026-01-17 19:23:13] |
| Sierra_Chart Engineering - Posts: 25484 |
No it will not be a problem because this is only used internally, and in one specific place. It does not affect ACSIL: It is unclear if/when REPLAY_STATUS_UNSET is set/used, but seems to me this would break IsReplayRunning(). The new constant is used for an efficiency improvement with updating of the replay control panel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-17 19:24:59
