Date/Time: Wed, 25 Nov 2026 22:26:32 +0000
Prior day value area lines not plotting on TPO chart
View Count: 453
| [2026-01-16 17:08:49] |
| User763335 - Posts: 133 |
Hi not sure whats going on with this particular Market profile chart, but I'm unable to plot yesterday's Volume Value area lines(pVAH & pVAL) using the "Volume Value Area Lines" Study. This same study & config works on other charts (candle , footprint charts). Have tried both RTH only and ETH, same result. "Days to Load for Intraday Chart Data type" = 2880 , Adjust Propportional with Bar Period=No(tried Yes also). But when I delete the Market Profile & Volume Profile studies and have only the "Volume Value Area Lines" study, they plot fine. Pls see the attached charts(1min Candle chart and Market profile chart), with the relevant studies included. thanks |
Private File |
| [2026-01-16 18:45:59] |
| Sierra_Chart Engineering - Posts: 25484 |
Refer to: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
