Date/Time: Wed, 25 Nov 2026 22:26:28 +0000
v2863 detached my Chart Trade windows and will not re-attach them
View Count: 714
| [2026-01-16 16:42:57] |
| User247273 - Posts: 51 |
I updated to v2863. I have a chartbook with 6 charts and each chart has been set up with the trade window attached to the chart. After updating to 2863, the trade window on every chart is detached. If I use Trade>>Attach Trade Window to Chart, the Trade Window does attach as expected, but it only stays attached while that chart has focus. If I switch to a different chart and then come back, the Trade Window is detached again.
| [2026-01-16 18:35:42] |
| Sierra_Chart Engineering - Posts: 25484 |
This was an inadvertent issue which is now resolved. We will have a new release out tomorrow. We cannot do a new release right now because there is some additional work we need to finish with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-16 18:36:52
| [2026-01-18 17:29:50] |
| ertrader - Posts: 701 |
This has been resolved in the latest release 2865. Thank you.
| [2026-01-19 02:57:35] |
Yes. Thank you.
