Date/Time: Wed, 25 Nov 2026 22:26:25 +0000
market order latency question
View Count: 475
| [2026-01-15 20:21:32] |
| User887126 - Posts: 101 |
Hi, I am testing out new company for vps near cme. i use acsil with only one instance, one chart for this service. i am seeing about 90ms from the time market order is submitted and the order is filled. it is much longer than what i was expecting with vps. I set my chart refresh interval setting (10ms) and other parameter that SC engineer recommended. What is the lowest time i can expect for market order to be be filled using just regular vps? what will this time be if i use colocated server? please advise. Date Time Of Last Edit: 2026-01-15 20:22:12
| [2026-01-16 04:52:58] |
| Sierra_Chart Engineering - Posts: 25484 |
This is impossible to say. There is more information here about this: Sierra Chart Teton Futures Order Routing: Low Latency Order Routing 90 ms is definitely high. Also understand, the routing is still going to be over the Internet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
