Date/Time: Wed, 25 Nov 2026 22:26:26 +0000
sierra chart is really slow today
View Count: 425
| [2026-01-15 16:42:30] |
| User423973 - Posts: 8 |
its only showing downloading data but takes a lot of time really to download it has haoppned for the first time
| [2026-01-15 17:39:53] |
If it is showing "Downloading Data", then the system is downloading the data. This can take some time if it is the first time data is being downloaded for a symbol. It also depends on how much data is being requested and how highly traded the symbol is (more trading means more data).
| [2026-01-15 19:20:40] |
| Sierra_Chart Engineering - Posts: 25484 |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
